Sponsored by:
Sponsored by:
How do I take the front bumper off?
Old 01-11-2007, 07:00 PM
blackout
blackout's Avatar
Default How do I take the front bumper off?
Okay how do I take off the front bumper!!!! I'm having a lot of trouble figuring it out and I can't get those rivets out how do you do that? I need to change my fender and can't get those stupid things out any help GREATLY appreciated...
Thanks, Jeff
blackout is offline
Old 01-11-2007, 08:20 PM
xbone
xbone's Avatar
Default RE: How do I take the front bumper off?
Havent tried on my 06, but cant be much diff than my 04 Mach was, two retaining nuts on each side behind the fender well plastic, 10mm nuts, a couple of plastic push pins, maybe some philps screws, voila.Pop off the fender well plastic first and look with a flashlight, cant be hard.
xbone is offline
Old 01-11-2007, 08:36 PM
blackout
blackout's Avatar
There are little rivets that are hold very strong and I cant get them off... I know people have changed there bumpers on here but nobody will share the info...
-Jeff
blackout is offline
Old 01-11-2007, 08:37 PM
fairlane292
fairlane292's Avatar
There are no rivets (unless you mean the plastic push pins on the plastic cover above the grill opening). Or do you mean the inner fender well plastic push pins? Once these are removed it's all 10mm bolts as I recall. Can check again when I get home. Let me know more specifically what you are struggling with, fr bumper removal is actually easy.
fairlane292 is offline
Old 01-11-2007, 08:44 PM
blackout
blackout's Avatar
yay fairline please help. There is a bracket that has a pin through it with a thread on it and it also has the fender connected to it as well. How do I get them off? Also do you know how to get the side skirts off? I'm trying to break down the price of a big repair I have coming up...
-Jeff
blackout is offline
Old 01-11-2007, 08:48 PM
xbone
xbone's Avatar
Dude, there should be 10mm nuts on the other side of the rivets you are talking about, pull the fenderwell liner away and look closer.
xbone is offline
Old 01-11-2007, 08:50 PM
blackout
blackout's Avatar
It is a flat topped stud and is there are threads, I had an accident at the track and maybe they broke off but I cant get those studs out...
-Jeff
blackout is offline
Old 01-11-2007, 08:51 PM
hammeron
hammeron's Avatar
Here is a link to the front bumper exploded parts.....have not
found the actual procedure yet...
http://www.swaaggs.com/documents/rem...t%20bumper.pdf
hammeron is offline
Old 01-11-2007, 09:45 PM
howarmat
s197 Junkie
howarmat's Avatar
That link is good but this is better!
http://store.roushperformance.com/im...structions.pdf
howarmat is offline
Old 01-11-2007, 10:03 PM
fairlane292
ORIGINAL: howarmat
Yeah, that link is excellent; I don't recall step 6 but it's been a while. Can't visualize what you are referring to, hard to imagine the hex head is gone off of a 10mm bolt, even from an accident. Can you take any pics? I haven't looked into taking the rocker covers off. Maybe someone here has a .pdf schematic for that as well.
Quick Reply: How do I take the front bumper off?
