seafoam.. which hose?
I've been reading some old posts about seafoam and I want to run it through my 06 GT but I'm not sure which hose to use to suck it up. Can someone tell me?
old posts..
https://mustangforums.com/m_2088843/mpage_3/key_/tm.htm
https://mustangforums.com/m_2205188/tm.htm
Thanks in advance....
old posts..
RE: seafoam.. which hose?
i love seafoam. that stuff is truly amazing
i did it to my 96' bronco. knocked the idle rpm down from 1000 to 650, got rid of the ticks in the engine, saw a much smoother runnig engine, as well as a good increase in eccel
i put a can of it in my gas tank every now and then. it really seems to help my 351 w/ acceleration
You should change the oil and filter after aspirating the SeaFoam through the intake. It realy alters the chemistry of your oil's add package and specifically lowers it's TBN (which protects the metals from acid-process corrosion).
