FRPP stingers?
FRPP stingers?
Am I the only one that has the drivers side tip sticking futher out than the passenger? It annoys me to no end. I even tried loosening the H pipe clamp to see if I could slide the whole pipe forward some, but no deal there.
RE: FRPP stingers?
mine is the same, the left one is up higher than the right one, it is very noticable. I am going to go back under this weekend and loosen up the clamps and try again to get them aligned...if not, to the muffler shop I guess to see if maybe he can shorten the right hangers for me....
RE: FRPP stingers?
The tips stick out about the same length on mine. The right one is just a bit further out, but you can't really notice it unless you stand there and stare at it for a few seconds. The only problem I had was that the right one didn't align properly. It would be off to the left while theother one lined up perfectly. I had to remove the right one and bend the hanger brackets slightly. Both are now lined up properly.
RE: FRPP stingers?
Mine have not stuck out further than the other but i did have a hell of a time aligning them. I ended up having my son hold the muffler in the perfect position after loosening all the clamps and then while he held it in place i tightened all the clamps and they are both centered almost perfectly now.
Richard
Richard
RE: FRPP stingers?
After the Headers and X pipe one of my zoomers is farther out then the other, but it will be addressed when we do the suspension. I noticed it after we dropped down the car, so I said no big deal. We will adjust it when the car is back on the lift for the suspension.
You need to adjust both the connection to the mid pipe and the muffler to over axel pipes to get it right
