Some kind of brownish redish fluid...
RE: Some kind of brownish redish fluid...
Normally brake and power steering fluids are clear while ATF is usually red. You will have to stick your head under the car to see where it is coating the components of the car. Since you have an auto and it is leaking in front of the engine then I suspect that it is one of the fittings connecting the tubing from the tranny to the radiator. Your tranny cooler is built into the radiator so look for two 1/4" metal tubes connecting to one of your radiator end caps. Hopefully it's one of the tubing fittings and not the cooler itself.
Just for grins, check your power steering pump to see if the fluid in your car is red. Broncos used to have a problem where if you started them with the wheels turned, the darn pump would start spewing fluid for a few seconds.
Good luck.
Good luck.
ORIGINAL: 6xStang
a competent dealer should be able to fix you right up. (emphasis on "competent" and "should")
ORIGINAL: LoLO
Too much fluid ? that's BS. If that was the answer it would have leaked at the begining or right after a service not just like that this morning.
Now that you tell me that... Maybe it happens when I start with my wheels turned..
What was the solution to this problem ?
Anyway, Im going tomorrow so I'll let you know.
I poked my head under the hood of my GT this morning and the power steering resivoir is on the drivers side of the radiator and the fluid is clear so I doubt that it is power steering fluid unless it is getting really contaminated. Also ATF is bright red, like cherry flavored cough medicine. You should have someone else start you car while you try to observe where it came from.
Finally the Bronco fix probably wouldn't work here as we would go looking at other F-series or E-series trucks for better parts and just swap them out.
Again good luck
Again good luck
AmericanMuscle4.6GT
11-10-2015 02:06 PM
treesloth
09-28-2015 07:03 AM
mrappe
09-26-2015 10:16 AM
