Some kind of brownish redish fluid...
This morning when I left, I noticed that the car was leaking some kind of redish fluid. not too much just when I started the engine.. then when I was going I couldn't really notice. Its not the first one it did that to me, they should have fixed that by then. Im going back on friday so they can do something about it !
has it happened to anyone ?
RE: Some kind of brownish redish fluid...
Stick or auto?
Also, did you get an idea of where it's coming from (front of car, rear, etc)?
Never noticed it on mine, but I seem to recall people having problems with the tranny leaking (on autos I think?)....dealership would claim there was too much oil...might try a search. Good luck!
sounds like trans fluid to me. I think even the Ford manuals use auto tranny fluid these days? Certainly the Tremec T56 does. A quick look under the car should isolate it....and a competent dealer should be able to fix you right up. (emphasis on "competent" and "should")
depends on where it is leaking from, could be the main seal but did you have the tranny oil changed. IF its from the rear its the rear pinion seal. So good luck and have it checked
