quick question about factory warranty!
RE: quick question about factory warranty!
ORIGINAL: doodad
Thanks guys.. looks like it is all up to dealer! well, i know clutch is not covered by warranty and my clutch is slipping. (stock car with 16k miles on and i amnot racing everyday and matue enough to know how to drive a car normally). My wife is working for ford motor co. at dealer development and she has some dealerships to go sometimes and do bussiness.. she talked to dealer owner and he asked me to come by and drop the car and he can prive me a loan car. i am hoping they would cover but i really doubt it.. another question, pro 5.0 shifter has NOTHING to do with clutch right?
thanks again.
thanks again.
ORIGINAL: shaners90lxhatch
Not really. Your clutch shouldn't be covered regardless of what shifter you have installed. Driving habits andbroken components and physical contamination (oil, water, et cetera) are what destroys clutches. In reality, you are shifting much more agressively than the stock system would allow with an aftermarket shifter. Therefore because the vehicle is capable of operating in a manner it was not originally designed to do (because of your shifter), it really is related. Operating a vehicle abnormally usually results in abnormal effects but I don't think you are going to heat specifically because of the shifter. Again, regardless of what caused it - it likely wasn't anything other than the way it was driven. Anyone other than you or your wife had time behind the wheel? Is your wife agood manual driver?
Not really. Your clutch shouldn't be covered regardless of what shifter you have installed. Driving habits and broken components and physical contamination (oil, water, et cetera) are what destroys clutches. In reality, you are shifting much more agressively than the stock system would allow with an aftermarket shifter. Therefore because the vehicle is capable of operating in a manner it was not originally designed to do (because of your shifter), it really is related. Operating a vehicle abnormally usually results in abnormal effects but I don't think you are going to heat specifically because of the shifter. Again, regardless of what caused it - it likely wasn't anything other than the way it was driven. Anyone other than you or your wife had time behind the wheel? Is your wife a good manual driver?
ORIGINAL: doodad
Thanks guys.. looks like it is all up to dealer! well, i know clutch is not covered by warranty and my clutch is slipping. (stock car with 16k miles on and i am not racing everyday and matue enough to know how to drive a car normally). My wife is working for ford motor co. at dealer development and she has some dealerships to go sometimes and do bussiness.. she talked to dealer owner and he asked me to come by and drop the car and he can prive me a loan car. i am hoping they would cover but i really doubt it.. another question, pro 5.0 shifter has NOTHING to do with clutch right?
thanks again.
thanks again.
It is illegal for a Dealership to void your warranty simply because you have modifications to your vehicle. It is the Dealerships responsibility to prove that any modification was the reason for a failure. With that said, some Dealerships are more performance oriented and willing to work with customers. It would be my suggestion to consult with your local Dealership regarding their warranty specifics. Also if you read the fine print on any auto warranty, "Drag Racing" will void your warranty. (of course they have to catch you racing and prove it :-) hehehe)
Screw the warranty, to restrictive, I gave up on my warranty at around 18K miles
I was black balled in fords computerwith Gears, Tune, CAI.. they told me that Rear end gears throw off the engine calibration ??? Dorks
[IMG]local://upfiles/25187/A5A45D9D13924BE3950E5384314A1A96.jpg[/IMG]
ORIGINAL: 2k05gt
The rear end does, in fact mess with the PCM in regards to shift strategy. The IATand MAF code are the reason it hesitates.Your CAI is the source of your MAF code in all likelihood.You can't mod a new car as easliy as an older car. The PCM just monitors too much stuff and there are more consequences for said actions. I work at the hotline that dealer called. A friend of mine took the call. I will be glad to discuss this matter with you if you are interested. Besides, I am curious to see how this all worked out.......
^ that is the exception. BTW doodad, I hope I didn't sound like a jerk. I really did not mean to be sarcastic or mean in any way
It depends on the dealership, I already talked to my dealership(Hawk Ford, OakLawn IL) and they said that the only way they would void the warranty is if it directly had something to do with the problem. The service manager also told me that if I think any given problem was caused by an aftermarket part, just take it off before I bring it in. They are very understanding about mustang owners addiction to modding their rides.
