Sponsored by:
Sponsored by:
Will fully syntentics 5W-20 oil be too thin in summer time?
Old 01-27-2007, 02:57 AM
NewMustang
NewMustang's Avatar
Default Will fully syntentics 5W-20 oil be too thin in summer time?
The V6 uses 5W-30, so there is no problem there. But I'm getting a GT, and will beputting 5W-20 fully synthentics in the V8. Will it be too thin in summer time?
NewMustang is offline
Old 01-27-2007, 03:06 AM
Ford_Dude
Ford_Dude's Avatar
Default RE: Will fully syntentics 5W-20 oil be too thin in summer time?
Ford says 5w-20 so if your stock use 5w-20
if the engine is damaged tell ford to fix it
after the first summer you'll know
Ford_Dude is offline
Old 01-27-2007, 03:44 AM
NewMustang
NewMustang's Avatar
ORIGINAL: Ford_Dude
Thing is... Ford uses synthentics blend, I'll be using fully synthentics which is thinner than blend.
Old 01-27-2007, 03:46 AM
Riven02
Riven02's Avatar
I use Mobile 1 5W20 all summer in Texas
Riven02 is offline
Old 01-27-2007, 04:10 AM
algregory
algregory's Avatar
Synthetics handle hot and cold way better than Dino oil.
algregory is offline
Old 01-27-2007, 04:17 AM
Trapeze
Trapeze's Avatar
ditto
Trapeze is offline
LAK3RS
LAK3RS's Avatar
Is 10w30 okay?
LAK3RS is offline
Old 01-27-2007, 11:02 AM
6xStang
6xStang's Avatar
5w-20 synth at operating temps is the same viscosity as 5w-20 dino at operating temp.One beauty of it is thatsynth is also 5w-20 at freezing temps, while dino oil is molasses. And...supposedly retains it characteristics at higher temps than dino.
6xStang is offline
Old 01-27-2007, 11:41 AM
TElke1
TElke1's Avatar
ORIGINAL: Riven02
+1!
TElke1 is offline
Old 01-27-2007, 12:04 PM
bodyputtyless
bodyputtyless's Avatar
It matters not "what" comprises the oil. What matters is the viscosity weight. 5W 20 is 5W 20 regardless if its synthetic or sunflower seed oil. It has been measured and graded at that weight level. Pour points may very but the weight remains.
bodyputtyless is offline
Quick Reply: Will fully syntentics 5W-20 oil be too thin in summer time?
