Sponsored by:
Sponsored by:
Is the LSD in the GT clutch-base or Viscous-base?
Old 01-30-2007, 03:16 AM
NewMustang
NewMustang's Avatar
Default Is the LSD in the GT clutch-base or Viscous-base?
Is the LSD in the GT clutch-base or Viscous-base? Which one is better?
NewMustang is offline
Old 01-30-2007, 04:02 AM
jerjan
jerjan's Avatar
Default RE: Is the LSD in the GT clutch-base or Viscous-base?
Say What?
jerjan is offline
Old 01-30-2007, 06:06 AM
NewMustang
NewMustang's Avatar
I'm talking about the rear limit-slip differential.
Old 01-30-2007, 07:18 AM
scrming
scrming's Avatar
Trac-Lock uses clutches...
scrming is offline
Old 01-30-2007, 11:35 AM
CrazyAl
CrazyAl's Avatar
Yep, it's clutches.
Viscous-type LSDs are typically used as the center diffs on AWD systems.
CrazyAl is offline
Old 01-30-2007, 10:14 PM
jerjan
jerjan's Avatar
OK, I get it LSD does not = very bad drug. One of these days I am going to post a very wild dictionary based on all these crazy abbreviations.
jerjan is offline
Old 01-30-2007, 10:37 PM
my77stang
my77stang's Avatar
i always thought a traction loc / limited slip were the same and as such would only lay down one strip of rubber. well, i decided to beat on my baby the other day and do a brake torque followed by a hellofa burnout. to my surprise i had two kick *** strips of perrelis going down the road. maybe i'll post a pic
my77stang is offline
Old 01-30-2007, 11:07 PM
Timmay!!!
Timmay!!!'s Avatar
Traction lok is just the nameof ourLSD. You can rebuild a T-Lok to lock up pretty good but a tru-trac(Helical geartype LSD) is even stronger andsilent, no moaning around corners.
Timmay!!! is offline
Old 02-03-2007, 02:55 PM
jerjan
jerjan's Avatar
Only problem with the T-lok is, it does not hold up well under lots of HP, If your T-lok goes bad, it is best to replace it with a better unit like an Eaton or an Auburn pro.
jerjan is offline
nonstopred
07-31-2006 12:34 PM
V6MustangKnight
06-20-2006 10:03 PM
HxCory
06-02-2006 06:15 PM
TJ
05-16-2006 08:52 PM
Big Red
03-06-2006 10:25 PM
Quick Reply: Is the LSD in the GT clutch-base or Viscous-base?
