Changing rearend oil?
RE: Changing rearend oil?
Most likley not. I do not think there will be enough clearance to use a funnel. The only thing you might be able to try is to some how rig a hose to the top of the gear oil bottle and use the bottle. Why don't you want to use a pump? It makes thing so easy.
Richard
Richard
Thanks. I've never changed gear oil before so i wasn't sure if a pump was necessary or not.
ORIGINAL: 06GT4RAD
Richard
Richard
You should also get a vacuum pump to draw the old gear oil out. Saves you from removing the cover and possible leaks resulting from such. Boy - a dollar bung and drain plug on the housing would have been great.
Now you tell me! I've allready been to carquest and advanced auto and got a hand pump that attaches to the quart of oil. Carquest had vaccum pumps that you use to suck the oil out and I guess squirt it in. Carquest is the only place in my area that carries royal purple gear oil.
I bought some grey gasket maker, but I might just get the vaccum pump and suck out the old oil. Is there any disadvantage to doing it that way?
ORIGINAL: Stooge
Instead of buying another pump to suck the oil out simply go to Ace Hardware and buy a longer piece of clear tubing/hose to attach the the pump you already have and use it to suck the oil out.
Richard
Richard
