Can I use my current LCA's with new driveshaft?
I am considering a one piece driveshaft but I will NOT be lowering the car. Do I still need adjustables or will my current Steedas do? Will the new pinion angle be that far off? What are the consequences? Thanks.
RE: Can I use my current LCA's with new driveshaft?
I just read yesterday where someone did this, and their pinion angle was right on. It was the Denny's Driveshaft thread onModularFords.com.
http://www.modularfords.com/forums/2...num+driveshaft
Dave
Dave
I find it very hard to belive that someone changed out the driveshaft to a 1-pc and the pinion angle was still correct. The attached image is exaggerated to make it easy to read, but it shows how the pinion angle changes when you install a 1-pc driveshaft. A "wrong" pinion angle has various effects. The most basic is increased U-joint and pinion bearing wear. It can also cause vibration and "clunking" sounds if it is bad enough.
I would get a set of adjustable LCAs. Or if you prefer, keep your Steeda lowers and get an adjustable upper.
[IMG]local://upfiles/32957/241F96E10AD94AD59DC1D4EC8F8281AA.jpg[/IMG]
Thanks Crazyal, from your drawing it would seem that that the LCA's would have to be shortened to correct the new angle difference. I read that other thread, and the member said he wound up with a -2degree angle after the install. If I remember a 0 to -4 degree angle is OK for the street, no?
Also, if I installed a new ring and pinion at the same time, wouldn't the pinion gear, being new and wearing a new pattern in the ring gear, lessen the chance of noise/vibration? I ask this b/c I'm considering changing to 3.55s, due to the inherent noise issues most of us are having with our 3.73s. Noisedespite my multiple attemps to fix it including that Redline Heavy oil you recommended.
Thanks again in advance.
-Rob
-Rob
0 to 4 degrees is a pretty large range.
The perfect setting depends on your driving style (in other words, a drag-strip car has different needs than a daily driver), and also on your suspension mods.
The idea is that during most of your driving, the pinion angle should be at a certain spot. With the OEM driveshaft, which has a CV joint, you want the pinion to end up exactly inline with the rearmost portion of the driveshaft. With a 1-pc aftermarket shaft which has Cardan joints instead of the CV, you want the two joints (tranny end and pinion end) to be paralell with each other.
The problem is that when you accelerate hard the whole rear axle housingrotates a little bit as the chassis flexes and the bushings in the controm arms squish. You want things set up so that during most of your driving the pinion angle is dead-on perfect.
An angle of about 2-2.5 degrees, in my opinion, is about right for a street car with common mods. If you stiffen the rear suspension by adding more aftermarket parts then the flex will be less, so you can make the angle less..say 1.5 degrees. But zero degrees and 4 degrees are both very extreme settings.
This thread describes the pinion angle stuff in more detail. I wrote one post regarding the OEM 2-pc shaft and then another for aftermarket 1-pc.
https://mustangforums.com/m_2570375/tm.htm#2571016
Why not email Denny's driveshaft and ask them? If your car isn't lowered it's possible that no pinion angle adjustment is necessary. While crazyAl's drawing is correct, it's also exaggerated as he says.
If Denny says it will be fine then i'd go with that. They've been doing driveshafts for 29 years or something.
By the way I ordered my driveshaft from Denny's a week ago today and still no shippy of my shafty[:@][:@]. So I'd make a decision soon if you want it sometime this year.
Matt's 95 Stang
10-05-2015 07:16 AM
BeatnikFink
10-01-2015 08:00 PM
