Brake stand in a manual...
RE: Brake stand in a manual...
DISABLE traction control. Give the throttle a goose and pop the clutch. Immediately get back on the brake (careful not to brake too much) with your left foot. Voila! Try not to peg the engine at redline for long. Feather the throttle to keep the revs where you want it.
Then, when you get this downyou canbegin tograb second andslowly let off the brake. Creeping burnouts look soooo **** especially if you turn the wheel a bit and get it sideways.
Whats what, Line Locks? They are seloniods that lock the front brakes while you do a burnout etc. You press the brake pedel, engage the line locks and then let off of the brake pedal. Your front brakes stay locked until you release the line locks. I have a shift **** that has a switch that I use, like you would with nitrous. Here - http://www.pmpparts.com/index.php?ma...roducts_id=187
ORIGINAL: MusiccityGT
Same here Dkano. I got mine for the track, but can't resist a showoff burnout ocassionaly LOL....
Line locks from the factory? Hey, now there's a thought for Ford![:-]
ORIGINAL: shaners90lxhatch
