Advice on fixing my car
Ok my topic was moved so ill post another pic.
http://www.machinsanity.com/mustang/...t/DSC01290.JPG
Shop A from my under standing wanted to replace the whole side front and rear panel and the door panel.
Shop B wanted to cut out the dent on the rear and do the metal work by hand and then replace the door. Then paint and blend.
Shop B was a couple hundred more.
What is your guys' input on the best way to have this fixed?
Thanks
Mach
Thanks
Mach
RE: Advice on fixing my car
I know I'd want my panels replaced with OEM parts for an exact fit IMO. Since you don't have to pay a dime out of pocket I'd search for a bodyshop that does high end cars. It's your car and you have the right to have it fixed at a reputable shop.
Well with the cutting and repairing he said that would be better becuase he wouldnt have to replace that whole panel cuz that side panel runs the length of the car. So his reasoning in cutting is to minimize the loosening of the factory fittings and stuff.
Are you sure? Seems like pulling the whole car apart to replace the panels seems like it would cause mroe problems down the road..Im not expert though thats just my thought. He said if they do the metal work its all metal they wont use any of the filler stuff.
IMO the cutting and welding of patches would create problems down the road. It would be nearly impossible to get the panel straight again without filler. Cars are basically big puzzles and replacing these panels isn't as much of a big deal as you would really think. I know when my first car got hit in the quarter panel and they replaced the quarter I thought it would be major surgery. After hanging out in a really good body shop for the past couple years I've picked up on a few things and found out that it's really not as bad as it looks. I'd definatly go with shop A, it's cheaper (which insurance would like) and I'd consider it the "right way" to fix it. If they patch and blend, you'll probably see the patch spot under certain light. If they replace everything, it'll be your little secret
submit the quote from shop B,
insist on getting the insurance money directly (alot of companies will cut you the check)
take car to shop A for a cheaper, better fix
use the extra cash you got to ease your pain and suffering by purchasing some go-fast parts or at least a nice steak dinner
Go with new panels. Either way your car will need bondo. I would rather have it were the welds are. Instead of were your going to be shutting the door. I also agree in taking your time to find a reputable bodyshop not a chop shop. Dont accept your car back till your satisfied.
