gear noise in neutral?
RE: gear noise in neutral?
well, when i first start the car, and i let the clutch out in neutral, it begins a rattling sound, like something is engaging.
could you be referring to the same noise, that when you rev it in neutral, it makes like a winding down sound? like a full 5500 RPM rev? and u can hear it better with the hood open?
well, i definitely have some whine on decel (more of a flutter) that goes away on tip-in. Also goes away if I shift to neutral. I also have a hum/moan type sound above 25 mph, which is independent of throttle position or gear/neutral. I'm fairly confident the decel whine is the gears, i was mainly wondering if the hum could also be differential related.
btw- i have an auto tranny (sorry - shoulda mentioned that earlier).
ORIGINAL: richmod
will gear whine (decel) or (pinion) bearing noise still be there in neutral?
If this is something that has been coming on slowly over time without you modifying your suspension, then one of your pinion bearings is going south. If however this is the result of a suspension change then you need to have your pinion angle checked.
ORIGINAL: richmod
So from what your saying, the hum/moan I'm getting (which is present under all throttle conditions and in nuetral) is probably not gear or diff related, correct?
Since you haven't provided any additional information, I assume that the supension has not been modified. If your vehicle is still under the bumper to bumper warrantee, then I suggest having it checked by the dealer. My wife's 98 Grand Marquis started to develop rear end noise when it had only 20K miles on it. I opted to have the dealer work on it as it was still under warrantee. Upon return they told me that the ring and pinion gear were bad but to me it didn't sound like gear noise. I then checked the ticket and noticed that they replaced the front and rear pinion bearings as well as the ring and pinion gears. I suspect the bearings were the real culprit. The Merc now has 149K miles on it and it has not had another problem with the rear end.
I really need to crawl under my new Mustang to see how the carrier housing differs from my 96 C-150 and my 98 Grand Marquis.
Okay, here's my situation: Initial problem was axle hum above 65 mph only on acceleration. Dealer did TSB 5-20-02 (ring & pinion) - obviously didn't bother to set them up, 'cause they whined like a police car from 60-30 mph decel. Same dealer tried 2 more times to fix it, improved it but whine not gone. At some point in this process the hum started again, but this time at 25 mph and up until about 70 - independant of throttle or gear. Took it to different dealer, did TSB again and replaced ALL bearings (wheel bearings included), got rid of most (not all) of the whine, but hum was still thereAND he created a vibration at 70 mph. tried to fix that, couldn't - so they put in a whole new rear end. Guess what - new rear end had slightly worse decel whine, hum is still there, and vibration still there. After trying to rephase driveshaft about 3 times, they finally replaced the driveshaft by swapping it with another GT on the lot (new driveshaft from factory actually made vibration worse). So now - no vibration, but some mild decel whine 55-40 mph, and rear end hum above 25 mph (at 28-30 mph it is loud and has a woob woob type rotational sound to it). I'm going in next week to swap my 18" BFG wheels for 17" to see if anythinng changes thus isolationg the tires as the problem(s). I doubt it. BTW - all stock, no mods (yet).
Man, I feel your pain. This is probably a dumb question but did the dealerships check pinion gear to propeller shaft angles? I would guess after all that work that they would. Interesting that with each repair the problems changed and then with further repairs original problems re-occured. I read somewhere on one of the Ford Mustang forums that the replacement gears Ford uses are not the same as the originally installed gears. I don't know if it is true or not as I haven't been able to confirm this rumor.
Your problems have gone beyond my experiences and I wish you luck.
ORIGINAL: Centurion96
...did the dealerships check pinion gear to propeller shaft angles?
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
