Shift stick vibration makes leather rubbing noise!
Okay, so whenever I put the gear in either 1st or 3rd, the vibration from the shift stick would make some leather rubbing noise. I guess the leather around the shift stick is too tight.
Does yours make any such noise? I have the transmission fluid changed today, still didn't make a difference.
RE: Shift stick vibration makes leather rubbing noise!
ORIGINAL: Arwing
what.................?
Does anyone also get this kind of noise?
i know exactly the noise your talking about. its like, the leather is sticking to itself and making an annoying noise, or just the whole thing is in a position where it buzses.
Yes, I have this same problem. If i hold the shifter in 1st or 3rd it won't make the noise, but as soon as I let go it squeeks away. Nothing I can't stand tho.
vphokie, your car looks awesome! I love the white/black look. You going with black louvers or scoops? That would look even better
ORIGINAL: AmericanMuscle4.6GT
ORIGINAL: NewMustang
Does yours still make this noise? Since yours is a 05,the leathershould have been softened by now, right?
nope. sometimes, if its cold, or humid, or depending on conditions in general, the leather will do this, but i just jiggle the boot around a litte bit and its gone.
think of it this way: if the conditions are right, and you manipulate the boot correctly, you might be able to get it to make the noise. but its really not a problem at all to fix.
mine never made the noise, and then did it for about 2 days 6 weeks ago, then hasn't done it since.
09-01-2015 08:16 PM
