Sponsored by:
Sponsored by:
What speakers Fit?
Old 02-24-2007, 12:35 PM
RICAKILLA
RICAKILLA's Avatar
Default What speakers Fit?
What size speakers fit in the doors of our cars, i tried the search thingie but had no luck with that...I have the Shaker 500 btw...
RICAKILLA is offline
Old 02-24-2007, 12:49 PM
05 Mustang GT
05 Mustang GT's Avatar
Default RE: What speakers Fit?
In the doors you can install 5x7" There are several good speakers available. I went with Polk DB570's but a number of people have installed Infinities, JL, MB Quartz etc. Speakers are very personal based on the sound you enjoy. A number of speaker stores offer an install guide showing which speakers will fit. There are a number of threads showing where the tabs on the speaker needed minor adjustament to get the in.
05 Mustang GT is offline
Old 02-24-2007, 03:09 PM
WuStangKlan
I ♥ Acer
WuStangKlan's Avatar
What do you mean "fit"?
WuStangKlan is offline
Old 02-24-2007, 03:31 PM
MartyMoose
MartyMoose's Avatar
I'm interested to know too what size speakers are in the doors and rear deck.
I've looked at Crutchfield for aftermarket replacements and found "component" speakers with thismessage (note the 4th bullet):
Installation Details for your 2007 Mustang
Use the factory speaker brackets.
Use the factory speaker grilles.
A speaker adapter bracket is required, and it's included free with your speaker purchase.
Component speaker systems consist of separate woofers, tweeters, and crossovers. You'll install the woofers in your factory speaker openings, so we check those for fit in your car. You'll have to custom-mount the tweeters and crossovers, which usually requires drilling and running new wires.
MartyMoose is offline
Old 02-24-2007, 03:36 PM
WuStangKlan
I ♥ Acer
+1
ORIGINAL: MartyMoose
Old 02-24-2007, 04:08 PM
mlcrycc
mlcrycc's Avatar
The rear deck speakers are 6x8. I replaced mine with Infinity Kappas when I replaced my head unit. They made a major difference in sound quality, when coupled with the new head unit.
The factoryfront door speakers (not the subs) are "component" plate speakers. That is, the woofer and tweeter are actually separate speakers, combined on one "plate" that installs in one cutout opening. If you replace the front speakers, you will either need to replace them with a comparable plate speaker, or install your "woofer" part of the component speaker in the existing cutout, and then drill a new hole for the tweeter part of the speaker.
Mike
mlcrycc is offline
Old 02-24-2007, 06:01 PM
WuStangKlan
I ♥ Acer
Will it "fit"? that was the question.
Old 02-24-2007, 06:37 PM
mlcrycc
mlcrycc's Avatar
I must be missing the "it" in will it fit
According to Crutchfield, both 5x7 and 6x8, depending upon the speaker, will fit the front door. Here is the Crutchfield page for fit.....
Mike
http://www.crutchfield.com/S-9QTJ94R...c=01&wm=tn
mlcrycc is offline
jwog666
12-27-2021 08:09 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
mdg
10-01-2015 07:04 AM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: What speakers Fit?
