Changing Axle Ratio using STC Xcal2
RE: Changing Axle Ratio using STC Xcal2
Its done using a handheld tuner. I used my SCT after the 91 octane load, I set the gear ratio to 4.10 using the user profile option. Real easy and speedo dials right in.
I have an SCT2 through Brenspeed, version 1.14 and i am not seeing a user profile option on the handheld device. The options I have - with submenus -are:
Program vehicle - Install Tune / Return to stock
Vehicle Info -Read DTCs>Clear DTCs>Read Strategy>
Data Capture - Set up data capture
Dealer Info - Bresnspeed
LCD Contrast -
Device Info FW 1.14 / My Serial Number
What am I doing wrong?
LCD Contrast -
Apparently Brent locked out your end user tune modifications parameters. That is getting to be common with mail order tuners. If he didn't you would see a modify tune option.
uberstang1
09-20-2015 06:42 PM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
09-03-2015 07:14 PM
