Which Automotive Battery is Best
RE: Which Automotive Battery is Best
All non gel-cell batteries are pretty much the same. Theyre all made by 2 companies, 1 is Johnson Electric, damn cant remember the name of the other. So basically the difference in the battery is the warranty thats sold with it. But the battery is identical. The only ones that are different are deep-cycling batteries. Those are usually marine batteries though.
-P.
PS: Optima gel cells are the best though.
-P.
According to Consumer Reports all batteries rank different depending on size. Each year, different batteries rank the best in different sizes. Never have I seen one consistant brand rank well in all sizes. IF you know the size you need I can let you know which ranked well in that size,.
an optima will fit but you have to remove the battery tray and make a new on....i'll see if i have pics of mine and i'll post them....i have a yellow top i painted black and red to match my car....
is there a difference in the weight of all of these batteries listed?When the time comes to ge a new battery I would like to put on in that weighs the least but still gives my good CCA numbers of 500+. I thought the red topped optimas were pretty light (35lbs) compared to the stock 55lbs battery.
Any thoughts?
Any thoughts?
Look here for a little more info http://www.guide2batteries.com/automotive-batteries/
OK, our size is "65". Last time CR rated batteries was 10/06. Top 5 out of the 18 tested inthat size was:
1)NAPA 84 Select
2)Duralast 65DL
3)EverStart Maxx 65N
4)AC Delco Professional 65-7YR
5)Nascar XLT N65-S
Worst/ Bottom 3 were
16)DieHard WeatherHandler 30365 (North)
17)DieHArd WeatherHandler30365 (South)
18)Interstate Megatron MT65
1)NAPA 84 Select
2)Duralast 65DL
5)Nascar XLT N65-S
logan409
09-26-2015 07:43 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
