Twin Turbo UPDATE
#21
RE: Twin Turbo UPDATE
ORIGINAL: sw07gt
Exactly twin turbo setups spool faster. Was I also the only one that noticed it was only running 6.3 psi? Thats why the numbers arent that high, low psi and slipping off the dyno.
ORIGINAL: petepete
From what ive seen torque has been higher with turbos and hp high with s/cs which is one reason why the whipple woul dhav ehigher hp numbers. Torq wins races though. As for the twin turbo they are used to have less lag they will have no extra power over a single turbo with same boost
ORIGINAL: bl1nkage
Somethings got me a little confused.. Ive always thought turbos gave you more hp in the higher end of the curve, not massive amounts of tq...?
Since turbos are providing more tq, and its mostly not until the 2.5-3k range... I wonder if theres a severe jerk of acceleration when you nail it from down low in the rpm range? Cause its gotta be like .... 2.1k rpms, 285 tq - 2.5k, 300 tq - 2.9k, 410 tq. Bet thatll wake ya up huh?
#23
ORIGINAL: bl1nkage
First off, HP and Torque: A lot of gearheads think of these as two different things. But the truth is that they are intimatley related together. HP is calculated from torque. The mathematical formula for American units (HP and ft-lb) is that HP = Torque * RPM / 5252.
This is how a dyno works. A dnyo measures torque only. (There is no such thing as a "HP sensor"). It then calculates HP from the torque measurement.
Note that if you look at the formula you will see that at 5252 RPM the two values are exactly equal. Any proper dyno chart using American unitswill have the HP and torque lines cross at exact 5252 RPM. So, mathematically speaking, below 5252 Torque is higher but above 5252 HP is higher. But they are related together. So if someone gave you a mod that added 10% more torque to your car, it would also add 10% more HP a the same time....anything otherwise is an impossibility.
It's common in the motorsports world to talk about "torque" when people are actually meaning low-end power and to talk about "HP" when people actually mean top-end power, but this is not technically correct. At any given RPM point the two are linked together.
Anyway, turbochargers have a reputation for delivering more HP and little torque. This isn't entirely true. Turbos, like centrifugal superchargers, are inefficient at low RPM. At lower engine speeds they just don't work very well. Consequently they don't provide much of anything at lower RPM (HP and torque). However at higher RPM they are very efficient and consequently they make a lot ofHP and torqueat that point.
Superchargers of the roots and screw type are very effective even at low RPM. Consequently they make a lot of power and torque at low RPM. At higher RPM they work well too, but sometimes a turbo is more efficient.
So, if we were to make a litte chart of Turbo/SC performance at different RPM ranges, we might see something like this:
Mod: Low / Mid / High
Turbo: Minor / Good / Great
SC: Good / Good / Good
...of course this isn't particularly accurate but the point should be clear.
#24
Thanks.. I knew most of that but that cleared some stuff up. I still dont understand why they even have two estimations then... why even have HP if its just another way to measure TQ? Why not just have a "power" curve that measures your "power" throughout the rpm range... why should you need two different terms to measure it?
#25
Technically they are not the same value--TQ is a measurement of a force, and HP is a measurement of power...but if you have either curve you can simply calculate the other one. So, you're right, having both HP and TQ curves is redundant. So long as you had either one that provides all the information you'd need.
I suppose they are both listed becasue people are just used to it. To the average guy Torque readings are pretty much useless....but people love to hear HP numbers.
#26
Maybe Im understanding this wrong... but it seems to me like.. you have 2 curves.. the TQ curve which starts high and slopes down, and the HP curve which starts low and slopes up... Those meet @ exactly 5252. Now the angle of the slope is dependant on how much power you have through your rpm range. Your max TQ is always before 5252 and on the TQ curve, and your max HP is always after 5252 and on the HP curve.. right? Why you cant just take the upper parts of both curves and use that to measure the power? Something like this...
When you say TQ is used to measure force and HP is used to measure power, is it accurate to say say that TQ initiates movement and HP keeps it moving? I know that alot of TQ is what you feel... that pin you to the seat feeling you get when you step on it, but what is HP? I mean, what does HP really mean... you hardly use any of the rpm range after 5252, so what good is it to really have high amounts of HP?
#27
Thanks for all of the info guys, those last post cleared a lot up, i spoke with the guy this morning, he was running a 93 oct tuneat 6 psi and got those numbers, like many people said he went with a twin turbo setup for lag purposes. I think a lot of people are forgetting this is only 6 psi, he can put more on it the system is built to handle to power, butthis tune was made to be very conservative. I hope im making the right move on this, ill keep everyone posted with pics and info. Thanks again for all of the info.
PS. The rims are raceline wheels
#28
ORIGINAL: bl1nkage
#30
Remember to..Turbos are far more efficent than S/C's. In other wordsmore output power with less input power. Its takes quite a bit of HP/TQ to turn the S/C with that belt. The turbos rob the power from the waste or exhaust. There is power loss here from constriction BUT its less then a S/C. Turbos can make more power over a wider band then a single S/C.
If you really want to have fun go with a sequential setup with a S/C and a turbo. The little wind up cars like the Mitsubishi Evolutions I used to tune guys would do it all the time. The S/C was geared to kick in and give tons of power in the low to mid-range and then a monster turbo would be spooled and kick in when the S/C would fall behind.
Also if you go with the turbos you should DEFINITLY look into methanol/water injection. Cheap kit for under $500 that will let you run more timing and boost with cheap gas. The cooling effects are so much greater than any intercooler it can lower EGT many 100's of degrees. EGT's are a problem with turbos you have to keep and eye on. Its neat when you can pull over and light a smoke on your turbo..but your turbo don't like that!! lol.
