Ripping 1st & 2nd in under 3 seconds
Quick video of test drive, ripping through 1st and 2nd gears in less than 3 seconds. Car was on Nittos DR 315/35...10.5 inch rims.
http://s149.photobucket.com/albums/s...treettest1.flv
RE: Ripping 1st & 2nd in under 3 seconds
Morning Derrek
Took car to track last wednesday. Didn't run well at all. Above 6000 rpm it was running out of fuel. Spoke to Procharger. Apparently going above 6000 rpm generates a whole lot more boost and hp. This exceeded the capacity of the 39lb injectors. So have ordered 60 lb injectors and larger fuel pump. Problem was we were on the wrong diameter tires (which we knew), so we extended the rpm range to not run out of 4th gear in the 1/4 (which happened anyway). Have also ordered correct rear tires. Hey....that's why they call it Test N Tune.
steven
steven
jwog666
12-27-2021 08:09 PM
