Sponsored by:
Sponsored by:
Running Amp Power cord
Old 03-13-2007, 01:47 PM
RICAKILLA
RICAKILLA's Avatar
Default Running Amp Power cord
Any one have a suggestion on how to run a 4g power cord from the battery to the trunk? My main concern is getting it throughthe firewall? I was wondering if there is already a hole i can run it thru or if ill have to make one...
RICAKILLA is offline
Old 03-13-2007, 02:27 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Default RE: Running Amp Power cord
I ran mine through an existing groumet located behind the passenger side.
PROMETHEUS PRIME is offline
Old 03-13-2007, 02:35 PM
ANBAUTO
ANBAUTO's Avatar
I ran mine through a existing grommet on the passenger side thats just below the battery. Nothing currently runs through it.
ANBAUTO is offline
Old 03-13-2007, 03:24 PM
PROMETHEUS PRIME
Thats probably the same one I used too.
Old 03-13-2007, 04:44 PM
RICAKILLA
RICAKILLA's Avatar
Do i have to remove the battery to see this grommet? I looked for it and didnt see it at all...
Old 03-13-2007, 04:55 PM
techmanBDsStang
techmanBDsStang's Avatar
Here are some pics if it will help I took of mine. I ran though the grommet, in the wheel well towards the front to get closer to the fuse box area.
Click on the pic for a bigger image.
techmanBDsStang is offline
Old 03-13-2007, 06:33 PM
skilz4u2nv
skilz4u2nv's Avatar
I ran my through a an unused grommet on the passenger side that led from the battery to the inside of the car... then i just ran the power wire under the carpet and moldings all the way to the trunk
skilz4u2nv is offline
Old 03-13-2007, 06:47 PM
RyanAcosta
RyanAcosta's Avatar
Thats what I did as well but what did everyone hook up the remote wire to?
RyanAcosta is offline
Old 03-13-2007, 07:09 PM
techmanBDsStang
When I was using the stock head unit, I found and tapped intothe ACC wire that lead into the stock HU. Sorry but can't remember what color it was. Now I have an aftermarket HU and run off the ACC wire specific for the remote wire.
Old 03-13-2007, 07:18 PM
PROMETHEUS PRIME
I just ran my remote wire to a circuit only hot in run then to a switch so I can shut it off when my lady starts to complain.
Quick Reply: Running Amp Power cord
