Rear Springs - Which way is up?
Like the title says. I'm installing the FRPP lowering springs and want to know which end of the rear springs areinstalled "up" (or if it matters). The stockers look like the close wound coils are installed "down", but I've seen instructions from Saleen, etc that say to install their rear springs with the close wound coils "up". Guess its just too hard for Ford to put some instructions in the box.[:@]
RE: Rear Springs - Which way is up?
http://forums.bradbarnett.net/showpo...mp;postcount=1
This might help you but not for sure....i actually had mine done so I dont know for sure. The FRPP look like these steeds do if I remember correctly before mine were put on.
ORIGINAL: howarmat
I'm almost thinking that other than diameter fit for correctness top and bottom, that it wouldn't matter which end had loose wound coil, up or down.The compression is going to be progressive whether loose wound is top or bottom, it seems. If one approach gives a softer, less harsh ride I'd like to know about it. I'm sure we'll get the word on this.
Well, I ended up calling the Ford Racing Tech Line (1-800-367-3788) and asked them. According to the Tech Line, the tighter coils go "up" and if they are installed correctly, the writing on the springs should be right side up. Oh well, looks like I'll be flipping mine around this weeked. I found a photo on the web that shows the correct orientation.
Hugh
[IMG]local://upfiles/58459/78BD9271FB094D4DA16F01E09B21BAF4.jpg[/IMG]
Hugh
ORIGINAL: tr6nut
Hugh
Hugh
ORIGINAL: moosestang
closely wound go down. Atleast that's how I have mine and how someone on here told me. I acutally had them the opposite way at first.
by the way I didn't notice any difference with them up or down, still rode the same.
Looking at how they aremounted and the fact that the end coil on both ends of the spring is the same ID/OD, I wouldn't think it would make a real difference. However, I'm really **** about stuff like that and if its not "right", it just sits in the back of my brain and bugs me.
