Tail light bulb broke
Somehow one of the bulbs broke inside the housing on my right tail light. And I can't figure out how to take out the housing to replace it. Is there a tutorial anywhere on how to do this? Or does anyone around here know how?
The light actually still works but its a hazard with the electrode exposed like that.
RE: Tail light bulb broke
ORIGINAL: Spiffu
manual might be worth a read.
Believe it or not, changing a light bulb and switching to sequential headlights is pretty much the same process. So, if you ever wanted sequentials, this would be a good excuse to do the modification.
Anyway, here are directions from Webelectric Products. Be very careful not to drop the nuts in between the trunk and turnk liner! If you have a shaker 1000, then you may have to remove the bass, I had to.
Removing the Taillight Fixtures (the procedure below is used on both sides of the car)
1) Directly behind the fixture, remove the plastic fasteners that hold the trunk liner. Flex the liner back to expose three nuts that hold the fixture in place. Using a 7/16" deep socket, remove the nuts and pull the fixture away from the car body.
2) Using a small screwdriver, carefully press the connector retaining tab and disconnect the harness from the plug. Remove the grommet that holds the harness in the car body. Remove the tail light fixture from the car and take it to a work bench. Place a soft cloth on the bench in order to protect the lens.
3) Remove the sockets from the tail light fixture using a counter-clockwise twist.
You have an 06 and unless you have 36,000 miles on it I'd be taking the car to the dealership and let them replace the bulb. Its covered under the warranty. BTW The procedure to gain access to the bulb is in the manual. It isn't very clear in my opinion. Not like the old days when you twisted and pulled. Now you have to remove half the trunk to get at the bulb. Yeah I know I exaggerated a tad, but you'll see wjhat i mean when you try.
jwog666
12-27-2021 08:09 PM
09-25-2015 09:06 AM
