Help on witch way to go
I am wanting some feedback from you on which mod to do next. Along with my sig, I have a 1 piece driveshaft on the way (Denny's) and I will be lowering the car with the Eibach Pro-kit, FRRP shocks, CHE Adj-LCA's and Adj-Panhard.
Should I go with 3.73's (not 4.10's) or a torque converter and why should I go that way?
Thanks for the help.
Later
Later
RE: Help on witch way to go
I'd go with the gears. Either 3.73 or 3.90. I am of the opinion that 4.10 is too much gear for an Auto.
The torque converter is a good mod too...but most higher stall converters work best in conjunction with the gears. With the stock gears you won't see as much benefit. I'd get the gears first, then later add the converter.
twinturbomustang
08-30-2014 07:48 PM
94Cobrakid16
03-03-2006 09:35 AM
