Sponsored by:
Sponsored by:
Heading to the Track!
Old 03-15-2007, 10:43 PM
adidasUNT8
adidasUNT8's Avatar
Default Heading to the Track!
Hey guys....this will be my first time heading to the track....im going next Friday....are there any recommendations as to what i should do in order to get the best times.....and im going to have to run with the wheels i have now bc i dont have the time/money to put slicks on the stockers......but should i take out the spare and everything in the trunk??.....i have 4.10's.....what do most of you guys with 4.10s end up getting to.....3rd? 4th?.....thanks
adidasUNT8 is offline
Old 03-15-2007, 10:53 PM
mx07gt
mx07gt's Avatar
Default RE: Heading to the Track!
lower your tire pressure. Your tires will grip better.
mx07gt is offline
Old 03-15-2007, 10:55 PM
blueherd02gt
blueherd02gt's Avatar
Take your 20's off and if you dtill have the oem wheels put those on
blueherd02gt is offline
adidasUNT8
adidasUNT8's Avatar
thanks Mx07Gt.....what tire pressure would you go with?
Old 03-15-2007, 11:02 PM
TheDarkPath
TheDarkPath's Avatar
Do a small burnout to clean the tires off.
TheDarkPath is offline
Old 03-15-2007, 11:04 PM
mx07gt
mx07gt's Avatar
I personally would go 20 psi...
but hey maybe someone that drag races more often can give you an exact PSI.
the generral idea is to soften the tire so it grips better... you get the idea. That is what drag racers do.
take blueherd02gt's advice... those 20's will act like anchors.
mx07gt is offline
Old 03-15-2007, 11:10 PM
TheDarkPath
I don't think lowering the tire pressure is going to help much. There isn't much side wall with the 20s so lowing the pressure may distort the tire. Lowering it too much will cause the middle of the tire to raise up so that the edges are the only parts that are touching the ground.
Old 03-16-2007, 01:37 AM
06Redfire3V
06Redfire3V's Avatar
don't peel out at the start...wait till u feel ur tires gripping then roolll.
06Redfire3V is offline
Old 03-16-2007, 01:38 AM
viking396
viking396's Avatar
ORIGINAL: adidasUNT8
For short sidewall radial tires lowering the tire pressure gets you nothing, DO NOT USE THE WATER BOX and don't bother with long burnouts, a short spin is all you need for radial tires, oh yeah, STAY OUT OF THE WATER BOX (it should be automatic bittch slap for radial tired cars)With 4.10's you need to walk the car out of the hole, DO NOT launch higher than 1500 rpm and walk it out, this will get you the best times, don't launch to impress your friends or your short times will suck. You will be hitting 4th gear and oh yeah, she'll make the best times if you nail the gears at about 6500 rpms, don't powershft into 2nd unless you're sure she'll grip (mine smokes 2nd gear if I powershift)make sure you use the 93 octane tune and 93 octane gas.
Good luck and have fun!
viking396 is offline
Old 03-16-2007, 01:59 AM
jonpo
jonpo's Avatar
All you need is a quick burnout to get the junk off the tires (dirt, sand, etc). I have the 18" bullitts and I run about 21-22psi.
jonpo is offline
Quick Reply: Heading to the Track!
