SJB Nightmare Fixed. Complete Story!!!
#21
You're kinda late to the show Son...about 12 years late, the guy probably sold the car by now but carry on...
#22
Great they fixed the sound system, but what about the water intrusion source??? did they find a leak and fix it ...or do you get to go through this again the next time it rains. SBJ area leaks seem pretty common with the new mustangs and Ford (and it's dealers) does not seem to have a handle on how to repair them.
#23
Water leaks.... The water leak is coming from the windshield washer well ... There is a drain on both sides of the car the rubber sleeve has a slit in the middle that is suppose to open to let water out but close to stop creepy crawlers from getting in... Any diry or leaf debris will clog that opening. The well fills with water and when u accelerate it splashes in through the cabin air filter .... And heater box.... I chose to remove the sleeve/grommet all together and chance the crawlers... They are alot cheaper to fix than these electronics... If u reach down the firewall u and grab and pull downward they pull right out ...
FirePower
10-22-2010 08:29 AM
flragtop
06-15-2007 12:18 AM
