Wheel and Suspension Mods
I amgoing to be purchasing new wheels for my 05 GT.They will be 19-in and staggered 9-in front and 10-in rear. I am going to lower the car with lowering springs.
I need some advice on what to get for suspension mods. I want to knock out the suspension at the same timeI change my wheels. I really want to do this right so that I won't have to pull the wheels off again until the day I need to change tires. I don't want to just lower the car with lowering springs. I want to lower it and improve the car's ride and performance.
I am most likely going to be installing the Eibach Pro-System Plus kit. This kit comes with Pro-Kit lowering springs, shocks and a sway bar. What other mods do I need to finish off the suspension??? LCAs, UCAs, panhard something? There are so many suspension mods other than lowering springs.
Thanks for the help!
RE: Wheel and Suspension Mods
I just want to install what is necessary for a high-performance street application. Ride quality is important since the car is my daily driver. I'm not looking to take the car to the track. Drag strip possibly, but I really don't think I'll need to adjust the ride height or shocks at all. I would like to have the car "feel" more like a sports car.
So, in addition to the Eibach lowering springs, shocks and sway bar...
1. Adjustable Panhard
2. Adjustable LCAs
3. LCA Relocation Brackets
4. Camber Bolts
Why do I need "adjustable" panhard and LCA's? Any particular brands and/or construction materials (aluminum, steel, etc.)?
2. Adjustable LCAs
4. Camber Bolts
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
http://forums.bradbarnett.net/showthread.php?t=60937
In short, you pinion angle will now be off since you are lowering the car. You have to use the adjLCAs for that. The relocation brackets are also reccommended as the posts show. You dont have to do any of this. But you asked "I want to lower it and improve the car's ride and performance." What I gave you was the proper answer basically.Those mods are not just for the track. They would be ideal for "high-performance street application."
I have the BMR tubular LCAs with relocation brackets. I like them even though the install was kind of a pain. One of the brackets was bent and the spacers were too long. a vice, some elbow grease, and a hack saw took care of all of those minor issues. BMR's quality is top notch. I also have their radiator support/front swaybar delete and it was a perfect fit.
[sm=why.gif]Now my head hurts with too much information. [sm=thanx.gif]Thanks for the links. fd
A small drop, say 1" - 1.25", and you can get away with springs and non-adjustable shocks/struts and have a perfectly fine "street" ride. Anything over 1.5" drop and I'd go with howarmat's recomendations.
Whoa! I just found a BMR suspension package at StangSuspension.com. It's a little more money than the Eibach package, but includes a lot more components.
BMR Level 1 PackageIncludes:
[ul][*]Front Swaybar (Part # SB022)[*]Rear Swaybar (Part # SB023)[*]Tokico D-spec Struts & Shocks (Part # DSP-12)[*]Upper Strut Mounts (Part # SM001)[*]Lowering Springs (Part # SP009)[*]Adjustable Panhard Rod (Part # PHR006)[*]Control Arm Relocation Brackets (Part # CAB005)[*]Camber Bolts (Part # FC001)[/ul]
I'll just buy some Lower Control Arms to replace the factory ones and I should be good!
