IS THERE A WAY TO TURN OFF THE TPMS?
There is no option in the system chip to turn off, disable or adjust the pressure level valueof the tire pressure sensor system. the alarm goes off every 20 miles or so. So hitting reset is a bit annoying plus the dash light flashing all the time.
Just buy a set of sensors that mount behind / inside the valve stems. ~$55 each I think but no tire bands to buy or have come lose or break causing noise inside your wheel as you drive lol (bands have a slight tendency to break if you get the cheap ones especially)
The "car side" of the TPMS lives in the SJB, so you might be able to retrofit a SJB from an '06 or earlier car and eliminate the lights and warnings. BUT . . . there is some procedure (and scan tool equipment) involved to make your car recognize a new SJB, and it's at least possible that other SJB-controlled functions would be affected.
Ok, I am about to jinx myself but I installed a brand new set of GT4's (w/o sensors) about a month ago and my TPMS has only gone off a couple of times. Usually when I brake really hard. Cant explain it. I was really not looking forward to having to hit the reset button every time I started her up.
I *think* that the only legal requirement involves the warning lamp. Saw it somewhere in some official discussion, the thought being that the nuisance of the reminder would push folks into getting it fixed.
State inspection procedures may not be as lenient.
Norm
Norm
Norm
exactly
