Drivers side front lower then passenger side...
I noticed resently that the drivers side looked lower then the passenger side, well I just went out messured it and the drivers side is a full half inch lower. I messured the back and there even. Tire pressure also is about even throughout. Should I be worried about this? I know they weren't like this when I installed the Shocks&Springs, though I just resently noticed the problem.
Any ideas what it could be, or even if I should worry about it.
PS Car doesn't feel like anythings wrong.
RE: Drivers side front lower then passenger side...
I would think there is something wrong with the spring on the drivers side. It sounds like its prematurely sagging. It is not normal and I would get it checked out.
My Eibachs have 70K on em with out issues.
You may have most likelylost the Nitrogen pressin one of the Tokicos (the low one).
Unfortunately you'll have toremove your strut and compressthe spring to see if the center rod has any pressure on it. If it does have some, you can measure the pressure to collapse it by placing it upside down on a bath room scale. (block of wood would help protect your scale) record the start wgt and the wgt to start collapsing the rod and record the diff.
You can call that measurement in to Tokico800-548-2549 or dissasemble the otherside and compare readings.
If nothing else you will have the springs out and can measure their heights while you're at it.
ORIGINAL: spdbrake
Just got her back from the doc today. They couldn't find anything wrong! No frame, shock, strut, spring damage. They said don't worry about it. Now what? Measuring from the top of my wheel to the bottom of the wheel well, thereis 1/2' larger gap on the passenger side. Tire pressures are equal. I'm no mororhead but it doesn't take one to know there something wrong! Am I missing something?
ORIGINAL: tritonpwrd
That might be true but I dont think the shocks or struts are made to hold up the weight of the car. I could be wrong but i think thats the springs job and the shocks are there just to dampen the springs. I still think it might be a faulty spring.
ORIGINAL: spdbrake
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
