tri ax adjustable height and diver/passenger side settings?
hey those of you that have installed the tri ax shifter, did you guys attach the handle thing on the higher setting or the lower setting? according to the instructions the higher setting is more comfortable, but the lower setting is a shorter throw. and did you guys bolt the handle onto the right side or the left side of the shifter lever thing? the instructions make it seem as if either way works, but they state that it gets better clearance when installed on the passenger (right) side.
my tri ax arrived today but i plan on getting it installed at a shop because it seems too difficult for a newbie like myself to do. and i was just wondering what settings you use.
oh and btw, if i wanted to adjust the shifter height or driver/passenger side settings later, would it be a big hassle (like would i have to remove the whole shifter?), or is there a way to easily remove the boot and adjust the settings?
thanks for the info
thanks for the info
RE: tri ax adjustable height and diver/passenger side settings?
It's an easy install. You kind of have to put the handle on the passenger side, there really isn't enough room on driver side when your in 1st or 2nd, and the high setting is alot taller than stock.
