RE: Cheapest place to get the Dennys Drivershaft???
ORIGINAL: androdz
I want the dennys because of the warranty. I am sure I will break the driveshaft in the long run.
Andrew
Keep in mind if you break a Ujoint they will replace it for free, but will charge you for the parts. If you break the tube or a weld then they will cover that for free parts and labor. Atleast that's the way i read it. I don't think the tube will break, maybe at the slip joint if it does which I assume would be covered under the warranty.
