Installing rear sway bar
I just purchased a rear sway bar from a coupe. Is this a swap I can do myself or do I need a second pair of hands? Any special tools?Anystep by step instructions are welcomed. Responses from those that have done this mod are appreciated. Thanks.
RE: Installing rear sway bar
If you have a GT, you already have a rear sway.....................if you have convertible, a coupe will not fit....................the convertible is bent different for the supports that the Vert has.....
Cheers!!
Cheers!!
https://mustangforums.com/m_1670555/tm.htm
Might help you a bit.....I was thinking that the sway was different for the vert also.
mungodrums
08-29-2015 12:53 PM
