Another Hellion Vid
Another Hellion Vid
I made this the night before my engine exploded.
http://www.youtube.com/watch?v=YUN8bGf0lpw
She was running strong.
RE: Another Hellion Vid
She sure was, R.I.P
What was the plug used for....
ORIGINAL: jdback19
Wow, sorry to hear about your motor. After that video it occured to me that you "leaned things out" prior to finding that plug b/c you were so rich it was "off the charts". Did you ever richen things up AFTER you plugged in that thing? Or even check the A/F again? Perhaps you were running way lean after the fix causing the motor failure.
Where did you purchese the kit from?
When I leaned it out on the dyno it put the A/F where it was supposed to be at. When i pluged it back in a put the car back to where it was suppossed to be. With the engine apart it is easy to see what happened. It was indeed the 87 octane my dad put in the motor, it started pinging and shattered the number 7 piston it also put a bend in the wrist pin and cracked it into 3 pieces. You can see were the rod rattled around in the cylinder and then it destroyed the cage thats around the crank. The it smashed into one side of the block and made a crack then it smashed the other side of the block making a quarter sized hole and snapping the rod in half. Thats the time line that i have put together. I knew once i left my fathers house with the 87 octane that the car was running wierd. I can also garuntee that if it wasnt for the bad gas the car would still be kickin *** right now.
Love the video, music really captures the sorrow of when your motor broke down. Dude you had me crying for a minute, then I cheered up when you took it to the dyno shop . Hope everything goes well on the rebuilt engine!!
