Vortech HO Dyno Numbers
RE: Vortech HO Dyno Numbers
I kind of like my set-up because I can launch pretty hard on the stock tires without them going up in smoke. Not sure how hard you can launch a KB equipped car on the stockers? Anyone?
Damn those are some nice numbers from the Vortech HO guys!!! I will not leave the Dyno without 400HP lol!!! Where does this car redline? I seen dyno pulls all the way up to 6,600RPMS Thats ALOT!!!! Where should I have the Dyno guy cut off? 6,500?
Thanks
Thanks
ORIGINAL: pnsh3r
after seeing those torque curves I am definitely gonna stick with a screw type supercharger. More than likely a KB or ford racing's whipple.
The only benefit or virtue a screw type has over a centri is the down low grunt, which can also be a hinderance.
ORIGINAL: Supernaut
What's the advantage of a screw s/ctorque curve over a centrafugal?
That's the theoretical explanation. However, that theory is debunked when you apply some practical reasoning.Some people like to brag about how their screw s/c will give them instant power at 2,000 rpm, whichsome try to claim is an advantage on the street. I disagree, and here is why.
If a Corvette pulls along side you and go from a roll, are you going to leave it in a gear where your RPM's are in the basement......no. Either you are going to downshift your manual oryour automatic will do it for you, and in both cases your engine will be right in the sweet spot fora centri blowers power curve.
The real difference is that a screw type will make the car feel very torquey down low, which I admit is a nice feeling on the street.They are both good systems, and it is not a case of one being better than the other.
ORIGINAL: 50mustanggod
Thanks
Thanks
Yea i'd probably shift at 6,000 but where should I have them stop on the dyno? Because everyone is getting there high HP number way up at 6,500-6,600 rpms! Is 6,500 safe to do on the dyno?
