Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: How to Install H-Pipe
Step by step instructions for do-it-yourself repairs.
Pypes Off-Road H-Pipe Install (w/pics)
#41
RE: Pypes Off-Road H-Pipe Install (w/pics)
I've played around a bit with my exhaust. Borla's then straight pipes. Stock cats a off-road X pipe. If you want a great sound.....stock cats with straight pipes. Simple and Cheap. as far as rattle goes, check the clearance between the pan-hard bar and the exhaust. It's a tight fit around the rear axle. Other than that you could check the exhaust hangers for clearance between hook and rubber/brackect. Sweet]
#43
ORIGINAL: rshamekh
And .. How did you adjust the Stingers to be aligned perfectly? Mine is sitting a bit low.
#46
If you already have a tune from brenspeed or most other places for that matter, your O2 sensors will be turned off already. if you don't have a tune I suggest you get a CAI/Tune first then worry about mid pipes. JMO
#47
ORIGINAL: DeStonn
Another option is to get a set of MIL Eliminators.
http://www.brenspeed.com/mustang_2005/midpipes.html
#49
Anyone knowwhat size socket I need to remove the down-pipe to exhaust manifold? I know it's gonna have to be a deep socket but what size? I'm using Taco Bill's write up to plan my O/R Prochamber install. I wanna have everythingon hand before getting under the car and not have to run to the auto parts store to get the right socket size. Thanks!
#50
ORIGINAL: 2007CalSpec
