Audio Install how to?
Hey guys, wanted to know if someone could pass the link of a 05-07 mustang audio install how-to (if there is one) I need to add speakers, amps and need to know how to run the wire, and also how to remove door panels etc.
Thanks in Advance.
James
Thanks in Advance.
James
RE: Audio Install how to?
Try this to remove the radio: http://www.2005stang.com/gallery/alb...ceterpanel.pdf
and: http://www.2005stang.com/gallery/alb...81/console.pdf
and: http://www.2005stang.com/gallery/alb...oor%20trim.pdf
for the door trim
Good luck
for the door trim
Good luck
When i did my install i ran all new speaker wires including to the doors. Its a PITA! but well worth it. you have to run the wire up under the dash and then through the rubber tubing between the car and the door and pull it all through. I havent found any easier way to do it
ORIGINAL: ANBAUTO
Thanks
ORIGINAL: ANBAUTO
Actually I did run it that way and it ran through the fatory plug I simply used one of the unused holes on the large plug. I dont have any radio noise with this install either. It wast a simple task to get all the wires through it but i did it will persistance.
09-10-2015 08:39 PM
