Changed tranny fluid at 8K miles
This is on a 2005 GT manual
Fluid was surprisingly red. Very red. Not bright red, but not yet dark red/brown. I changed it because I've seen horror pitch black fluid before on cars as early as 7K miles, due to break-in. After the initial early change then 15-25K miles a change is good, for me at least.
Anyways, I guess Ford really built a solid tranny or something... Im puzzled. Ive never seen break-in and up to 8K miles be this red. Anyways, i guess thats good!
RE: Changed tranny fluid at 8K miles
Sounds great to me ....but I think the trans fluid is red because they put an additive in it to differentiate when a fluid is leaking what it is. i.e. trans, engine oil, etc. But glad things are running and wearing well.
ORIGINAL: ohnoesaz
I now have a little over 6K on the '07 Pony with 5-speed manual. Think I will change it soon and hope the transmission doesnt burn fluid as bad as the M5OD.
Well ive always been under the impression that tranny fluid changes color like engine oil... as in clean and red at the start (or honeyish for engine oil) and dark brown by the end...
I'm a Redline fan, so I put in Redline D-4 at 4.6k miles which is their better grade for a manual trans while still being an ATF fluid.
I'm also a "Tufoil" fan, so I added a 10% mix to the Redline D-4 ATF fluid.
I think it shifts better with the change, but, my last car always shifted like a hot knife through butter even after 260k miles.
ORIGINAL: ohnoesaz
On the other hand engine oil gets contaminated with combustion debris etc and that is why it gets dark.
Auto tranny fluid should stay red.
ORIGINAL: algregory
What is best for the 5-speed T5 in the V6 Pony ???
I know they recommend Mercon for the GT manual... I BELIEVE they recommend Mercon V for the V6 manual. Definately recheck those facts! I do know FOR SURE that between the V6 manual and auto and the GT manual and auto, the only two fluids recommended are Mercon and Mercon V. Since most newer brands cover both of these specs then you're ok either way.
One of these brands, and I prefer it, is Mobil 1's 'Synthetic ATF'. It covers Mercon and Mercon V, as well as many more. So you're probably best off with that.
Some people believe Mobil 1 is all name and nothing special, in that case I've never had a problem with Valvoline's Mercon V Synthetic ATF (also covers Mercon). Great stuff at about 55% the price of Mobil 1.
Again, im listing the readily available ones... If you want you can order AMSOIL, which many people swear by. I do not, as I believe all of these fake websites and tests are just marketing ploy by AMSOIL. They make great products, but I dont think they're anything that warrants a special order or anything.
Also, consider the additive Tufoil. Its pricey and you have to order it... But its the ONLY additive I've ever read of that gets no negative reviews at all, and only positive ones. Some people swear by it. Its the only additive that the FTC does not name as questionable or a fraud.
