1/4 window side louvers/ lower side scoops
04-27-2007, 08:52 AM
I just bought the 1/4 window side louvers and the lower side scoops for my 07 Torch Red Stang.
Any problems with adhesion using the3M tape that is supplied.
04-27-2007, 09:08 AM
RE: 1/4 window side louvers/ lower side scoops
Just make sure you prep. properly and you should be fine!
04-27-2007, 09:20 AM
No problems just make sure you line up everything...before you press that tape down
[IMG]local://upfiles/31319/5850082F9B7F4061B7351BEE5E19690F.jpg[/IMG]
04-27-2007, 09:40 AM
Did anyone use the "adhesion promoter" that was supplied that gets applied to the attachment points on the body of the car?
04-27-2007, 09:54 AM
I would defitnetly use the adhesion promoter...
04-27-2007, 04:09 PM
I've had them on for about two years now....no problems whatsoever. Like others have said make sure their in the right spot when you press down on them 'cause where they go they STAY!!!
04-27-2007, 04:16 PM
what do you have to do for the prep, just wipe down really good?
04-27-2007, 06:02 PM
I think rubbing alcohol if I'm not mistaken.
~Fletch~
GentleBen
09-11-2015 05:34 AM
96stang3.8
09-10-2015 06:42 AM
robjh22
Suspension
09-08-2015 12:47 PM
zachary1988
09-04-2015 03:04 PM
TimeLord101
09-04-2015 09:27 AM
