Sponsored by:
Sponsored by:
I'm trying to improve my brakes....stock blows
Old 04-27-2007, 04:41 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Default I'm trying to improve my brakes....stock blows
So I'm having Hawk brake pads installed with Russell Stainless Steel brake hoses. Should I pull the trigger on Rotorpros Cross-Drilled/Gas Slotted rotors as well??? Will they help???
mAnYsTyLeS is offline
Old 04-27-2007, 05:22 PM
androdz
I ♥ Acer
androdz's Avatar
Default RE: I'm trying to improve my brakes....stock blows
changing the rotos will have no difference, drilled/slotted rotors are more a decorative mod than anything else they offer no real perfomance gain. They were made for when break pads where made of asbestos. The only way you improve braking is A. Better pads, B. Better lines, C. Increase rotor diameter, d. Bitier calipers
Andrew
androdz is offline
Old 04-27-2007, 05:43 PM
zkiller
zkiller's Avatar
cross drilled rotors crack a lot dude!
zkiller is offline
Old 04-27-2007, 06:20 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
So what's better? (to avoid cracking) dimpled and slotted maybe????
Old 04-27-2007, 06:21 PM
Speedyejl
Speedyejl's Avatar
I'm pretty sure drilled/slotted rottors help cool brakes off, this obviously does nothing for intially bite though and is useless on the street.
Steel lines improve feel, they don't actually improve stopping distance.
Speedyejl is offline
Old 04-27-2007, 06:28 PM
daoh
daoh's Avatar
Here is a good read on brakes...be warned, it will take a while to read all the way through, but there is a ton of great info in it.
https://mustangforums.com/m_2547493/tm.htm
daoh is offline
Old 04-27-2007, 07:08 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
I just read this whole thing and got very dizzy......[&o]
Old 04-27-2007, 07:30 PM
howarmat
s197 Junkie
howarmat's Avatar
ORIGINAL: daoh
and the newbie comes through with the answer! I have the Rotorpros and so does tacobill. There are not a performance upgrade but a cosmetic upgrade. Get some of these and you will notice a huge difference in performance.
http://www.pmpparts.com/index.php?ma...443d69099e451a
howarmat is offline
Old 04-30-2007, 01:41 AM
androdz
I ♥ Acer
androdz's Avatar
ORIGINAL: Speedyejl
So you know more than wilwood does
http://www.wilwood.com/Centers/Infor....asp#question7
androdz is offline
Old 04-30-2007, 02:18 AM
Speedyejl
Speedyejl's Avatar
Androdz, you want to play this game?
All the Wilwood link says is that drilled rotors can save some weight for hardcore racers, something that won't matter so much on a street setup.
In regards to cooling Wilwood says nothing, if you do some research on Stoptech and Brembos sites you'll see them saying slotted rotors improve airflow and thus cooling.
Steel lines do nothing but improve pedal modulation, on a road course this could equate quicker lap times somehow, on the street it means nothing.
When it comes to braking it seems to be much more art than science. Brembo, Stoptech, and Wilwood are all respected manufactures, yet I'm sure their opinions will differ from area to area, from their own experience and possibly for marketing reasons. I really couldn't care to get into a technical debate, whatever. The bottom line is that on the street drilled/slotted rotors are for cosmetics.
Quick Reply: I'm trying to improve my brakes....stock blows
