Need Help with Headlight Switch/SJB Issue
I need to remove the headlight multi switch from the car to install a fog light rocker switch on it. When I disconnect the switch, the headlights come on because apparantly the SJB needs to see feedback from the switch otherwise it turns them on.
Is there an easy way to disable this? The options I see are: [ul][*]Disconnect the battery (don't want to deal with the relearn, etc.).[*]Pull the SJB fuse - I think 59 and 67 are related but will that work?[/ul] Any other ideas? Thanks. |
