What size is the bolt protruding out of the front left & right of the trunk?
Hey I'm installing a sub and picked the bolt on the left front of the trunk that sticks out (it's very obvious), as my ground wire mounting point. Unfortunatly it doesn't have a lug nut already installed on it. What size is the bolt? Also are there any other good mounting points?
RE: What size is the bolt protruding out of the front left & right of the trunk?
Is that the one that's painted over on top of the canal between the trunk and the passanger area? Or is it somwhere else...?
This is a picture from a Mustang Audio wiring job. I'm not sure where this bolt is though. So that would be a good one.
Also what do you think about connecting sound using the rear speakers outputs instead of a crossover, then setting the amp on low pass only? Will removing the bass from the stock speakers do much good?
I'm not quite sure where the seat might latch other than what I've circled twice. This is what I beleived you to be reffering to in the first post. I don't know if that's right though.
The bolt that I have circled once is where I originally intended to ground the Amp, I just need to know what thread the screw has,like machine, and what size it is, like 15mm.
[IMG]local://upfiles/47654/FDBA82D713064837BC89B8389E08EC6E.jpg[/IMG]
[IMG]local://upfiles/47654/DBCD90BBCE654253A147BC78D835BDE4.jpg[/IMG]
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
mustangsrforever!!!
08-06-2015 12:04 PM
