? on ZEX install/spark plug torque
I'm in the middle of the install and I forget the plug torque #'s (24-27lbs I think).
Secondly, with the fuel and nitrous supply lines it seems to me there should be
some kind of sealant used on the fittings to prevent leakage, am I wrong?
This install is ridiculously easy even for a beginner.
Thanks
Thanks
RE: ? on ZEX install/spark plug torque
You need high temperature thread sealer. A small tube will be sufficent as you only need a tiny amount. The spark plug specs sound correct, but you should call or email the manufacture.
breaking
10-02-2015 01:27 PM
