Cure for squeaking poly LCA bushings?
#21
RE: Cure for squeaking poly LCA bushings?
Ihave the BMR LCA's and Repostion brackets. I have noticed a little more road noise transfer but no squeaking or poping. I used silicone grease and have grease fittings in both ends of my LCAs. I think the spacer lenght on the brackets isimportant because if you pinch the bracket together it will put tension on the side of the bushing causing a rub.
