Tire and Rim questions
Ok, the rims I want are on back order so I'm now looking at American Muscle ChromeMach1 rims that are 17x9 all the way around. The fronts will have Sumitomo255/40/17 (25" height) and the rears will have Nitto (yes, I know BFG DR's are better) 275/40/17 (25.7"height).
So, Brenspeed tells me that even though the back are .7 taller I will not get tossed an ABS code while driving, AMerican Muscle insists I will and also says that 275/40/17 is 2.3 inches shorter than Ford recommends as they want the height at 28 inches. This is driving me insane, I need to know if people are running a slightly taller tire in the back and is ANYBODY running a 275/40/17 tire on their S197.
I plan on ordering SOMETHING tomorrow and the above is what I would LIKE to order but not if I have to worry about codes. Please don't respond with guesses, I need people with experience to chime in.
I spoke with 2 Ford dealers, both "guessed" I should be ok, so if they don't know how can I expect others to know? Easy, the people here rock!
RE: Tire and Rim questions
Nitto555 295/45/18 @ 28.31 inches overall diameter, no problems whatsoever. As for who is telling you the truth, try looking up the specs on your stock rear tire and seeing who's information matches the closest the the stock tire size.
I run 295/45/18 in the rear and I have no problems at all. Call Americanmuscle up and tell them they're crazy! I love the look and ride with this size tire. Since your going staggered why don't you go with a 10 inch wheel in the rear and run the 305/35/18 DR that Nitto offers? It will fit and will give you alot better traction off the line, which judging by the power your putting down you will need.
Oh by the way, are you from Illinois? I saw your tuned by Kurgan, I'm hoping to have him hook my car up soon too.
This should help with the sizing calculations: (stock is 235/55/17)http://www.discounttire.com/dtcs/infoTireMath.dos
It looks like you could get a lot closer to the stock size by going with: 255/50/17 and 275/45/17, unless of course you are going for smaller tires to "change" you effective rear gear ratio...
As far as the bigger/smaller than stock throwing ABS error codes, I have no idea.
ORIGINAL: Pantera72
ORIGINAL: Haze28
Next year I'll hook it up with 3.90 gears and a better clutch and then I'll install the BFG's and maybe lower the car a little bit.
ORIGINAL: daoh
Anybody have a calc that helps figure out what 25.7 inch tires reduce our 3.55 gears too when compared to the 28" stock tires? My brain hurts.
Try this, http://www.miata.net/garage/tirecalc.html
I don't know what your stock tires are but if you go down to a 17" wheel you could run a 275/45/17 to kind of make it work like a 3.90 or 4.10 gear, not really sure about the calculations though. I think I saw your car at Busse too, I wish I could have got a look at the blower. Nice set up you got.
Did you see this?
Did you see this?
ORIGINAL: Haze28
Did you see this?
Did you see this?
Anytime you want to se the set up let me know, I'll meet up and show you. I just eye balled the car, I don't know if my plan will look right, I think I'm going to be seeing a lot of the wheel wells but the new set will be wider. []
ORIGINAL: Haze28
Did you see this?
Did you see this?
Am I wrong?
