What's your idle rpm?
RE: What's your idle rpm?
ORIGINAL: Debo07GT
I am running a Brenspeed 93 tune and my car idles at 1200 rpm's for about the first minute after start up, then dropsto about 900 rpm. Is 900within a normal range or does it need to be lower? Sometimes it just seems kind of high.
ORIGINAL: GidyupGo
Those are the figures I have programmed into the PCM. There is absolutely no need to have the car idling at a high number while in neutral, hense the 620rpm. The reason for the 720 in drive idle is because I have under drive pully's on the car and want the idle to power my accessories, AC, stereo, battery, rocket launcher etc. etc.
Might want to get yours to a shop. Idle isn't supposed to go UP when in drive.
ORIGINAL: GT John
After warm-up 620 in neutral idle and 720 in drive idle.
when i turn on my car it idles at about 2500 and even goes to 3000 sometimes!!! i kno it's crazzyy. i hate it, when i get my dyno tune in a month hopeuflly it gets fixed. i heard it's cuz i have gotten it tuned from 2 diff. places??
ORIGINAL: ryterngki
They all will idle aound 1.2k for up to a minute or so in warm weather then drop to whatever your tuner is set to. It doesn't sound as if anything is wrong with yours. Do you know how to access the custom settings in your tuner to see if it's set at 900rpm?
