valve cover removal
valve cover removal
Can't look at the valve covers any longer.How long should it take to remove them ?How much is a new gasket set ,and should i go to ford to get them.Is the harness or any other parts in the way,or will they clear everything.I think i will have them powdercoated black.
RE: valve cover removal
http://www.cherod.com/mustang/Mods/ValveCvr.html
Check the above link for step by step. You don't need new gaskets, the urethane ones are reusable.
http://www.cherod.com/mustang/HowTo/ValveCover.htm
here is the step by step.....
the link on the main page doesn't work.
They are pretty simple to do, I painted mine black and added "FORD RACING" decals on after the paint. When reinstalling cover the valve covers with masking tape to prevent scratches. Total time for removal, cleaning, painting and reinstall 8 hours. Reused gaskets, with no leaks.
It took me about 45 minutes to remove the valve covers but that was taking my time. I also spent a lot of time trying to figure out how to remove the passenger's side without removing the battery. If you read the instructions and are well prepared, you should be able to get them off in about 20-30 minutes.
Thanks for the step by step!
ORIGINAL: drbobvs
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
