handling mods
what do you all think the best mod for under $300 would be that would help when cornering on bumpy roads, my steering wheel gets thrown around a lot if im going around corners too fast on non smooth roads.. besides new lca's what do you guys think?
RE: handling mods
Sway bars!
RE: handling mods
already have em
RE: handling mods
With 922 rwhp why....why would you limit yourself to $300 american?..Just a question!
RE: handling mods
Actually too stiff a sway bar can make it worse! So can really stiff shocks. Proper suspension set up is an art. Finding that delicate balance that makes the car corner like it's on rails and still handle bumps and pavement transitions isn't easy.
RE: handling mods
oshkosh, post your mods. Surely you don't have a stock internals 4.6L. Blown, nitrous, big block, time bomb maybe? Weight of thatwould effect your front handling. If you can afford 922 rwhp surely you can spend more than $300 to help your suspension and drivetrain.
RE: handling mods
ORIGINAL: oshkoshbajawsh what do you all think the best mod for under $300 would be that would help when cornering on bumpy roads, my steering wheel gets thrown around a lot if im going around corners too fast on non smooth roads.. besides new lca's what do you guys think? WIth apositve caster the steering wheel will be easier to keep straight and solid. The down side is that a higherpositive caster will increase the resistance in turning the wheel. |
RE: handling mods
is your car lowered yet? have you bumpsteered it?
RE: handling mods
ORIGINAL: Derf00 ORIGINAL: oshkoshbajawsh what do you all think the best mod for under $300 would be that would help when cornering on bumpy roads, my steering wheel gets thrown around a lot if im going around corners too fast on non smooth roads.. besides new lca's what do you guys think? WIth apositve caster the steering wheel will be easier to keep straight and solid. The down side is that a higherpositive caster will increase the resistance in turning the wheel. what do u mean by "wander?" |
RE: handling mods
1)the 922 is a joke, im sorry
2)looked into bump steer kit... but isnt it really hard to install thats what ive heard? 3)when i mean wander, i mean iw ill hit a bump and the steering wheel will get throw in either left or right direction and it causes my front 2 wheels to go either left or right quickly and i have to hold the steering wheel even tighter to ensure it doesnt lose total control |
