lowering my mustang
im going to be lowering my mustang this week. but i still cant figure out what spring to get. it dont like the pro-kit cause it sits to high.i amscared about thesportline. is there and kit out there that in the middle ofthose.
also does anyone have apic of a gton20 with sportlines springsinstalled thanks |
RE: lowering my mustang
Your car already looks lowered. Just use the Roush rear springs to even out the front and back.
Agreed don't lower the front, it's wrong. Back maybe but front is perfect.
+1 If you lower the front , you won't be able to drive it anywhere, it's pretty much as low as you'd want to get for everyday use IMO.
I dont know why everybody is against lowering the front. I did both with steeda ultralite springs and I think it sits perfectly now. Dropped the front 1" and the rear 1 1/4". Not a drastic drop but sits and handles great now. No rubbing anywhere at all. What was installed is as follows:
Steeda Ultralite Springs Tokico D-specs BMR adj. uppercontrol arm BMR lowers control arms BMR panhard bar and support BMR lca relocation brackets BMR rear sway bar |
I have the Pro Kit...and have had no clearence problems and I think it looks great. But to answer the question...the Sportlines drop you almost 2 inches and the Pro Kit about 1.5 rear...1.4 front. I do beleive the Ford Racing springs give you 1.5 all the way around; so while thats not much of a difference it will but you somwhere between the Pro-Kit and the Sportlines.
His front clip is about 3 1/2-4" off the ground now, a 1 1/2" drop gives him under2 1/2"of clearance. I personally wouldn't drive a car with 2-3" of clearance on the nose. You couldn't park anywhere where there's a parking stopbump, but to each their own, I guess............
ORIGINAL: wingman75 Your car already looks lowered. Just use the Roush rear springs to even out the front and back. |
I'd get the Roush's but i'm a little bias'd since thats what i have and i have the CDC classic chin on the way and i'm glad i didn't touch my front or i probably wouldn't be able to make it into my garage with the front lowered anymore. But like someone stated before the roush rears even the stance out nicely.
I have H&R race springs, which are about the same drop as Sportlines. I clear parking blocks by a GNATS ASS!!!!!
just lower the rear or kiss that air dam goodbye |
