Sponsored by:
Sponsored by:
These tires will fit... RIGHT???
Old 05-20-2007, 06:48 PM
  #21
waykooljr
waykooljr's Avatar
Default RE: These tires will fit... RIGHT???
I run 255's all around on 18x9 wheels.
What is the width of the stock 18's?
waykooljr is offline
Old 05-20-2007, 07:33 PM
  #22
RodeoFlyer
RodeoFlyer's Avatar
the stock 18" fanblades are 8.5, im assuming the 18" bullets are the same
You are corerect, the reccomended wheel size for my RA1's is NINE-11. I ordered NINE inch wide wheels. EIGHT inch wide wheels would be shoehorning them on. 10 or 11 wide wheels weigh more, which is obviously something I want to avoid.
Obviously per your link Falken is okay with as narrow as 7.5 inch forTHAT tire. That tire happens to be a 50 series tire, andis neither a common orpopular size of tire for the application we are talking about. The tire you are referring to is 28" tall - taller than the factory tires. If you look a little deeper and take note of the 40 and 45series tires, which are used widely - you will seea different story. There is always an exception to the rule somewhere, but in this case the commonly usedsizes in 275 width require a 9" wheel or bigger - occasionally 8.5".
RodeoFlyer is offline
Old 05-20-2007, 07:45 PM
  #23
howarmat
s197 Junkie
howarmat's Avatar
http://www.bigcustomwheels.com/
I like that calc too.
howarmat is offline
Old 05-20-2007, 08:15 PM
  #24
waykooljr
waykooljr's Avatar
Yea, the choice of tires in the 275's is slim pickings even with a 9" wheel. My personal choice would be the 255's on the 8's or maybe 8's in the front with 235's, 9's in the rear with 255's.
I think the actual rim width is different from 17's to 18's.
I gotta ask since I just noticed that 275/40/18 isn't in the list of RA-1's
http://www.toyo.com/docs/tires/produ...category=sport
What Toyo's do you have? T1R's, maybe?
Old 05-20-2007, 08:33 PM
  #25
RodeoFlyer
RodeoFlyer's Avatar
They're actually 275/35/18's
I've been running 17's till now. I have a connection that gets me scuffed/qualifying tires from a World Challenge team - hence the switch
Old 05-28-2007, 10:32 PM
  #26
moosestang
moosestang's Avatar
Well I'm unsure what I should do now. I ordered 275/50/17 drag radials from M&H. They said I could put them on a 17x8, but on their website it recommends 17x9. I still haven't ordered a dedicated pair of rims for them and the price difference between some 17x9 bullits and stock 17x8's is negligible. I'd like my rims to match, which is the only reason I was considering the stock rims.
I'll also be running this at low pressure at the track
ORIGINAL: RodeoFlyer
moosestang is offline
Old 05-29-2007, 12:50 AM
  #27
forensicsteve
forensicsteve's Avatar
I know my rims are wider but in response to driveability issues with wider tires, I have not noticed any difference. I don't use the Nitto 315 DRs on the track, where they're pretty useless, but they are very good on wet roadways. I have 2 sets of MTs (MT ETStreets& DRs). I would not use either on the street, unless I fancied going aquaplaning in the rain.
forensicsteve is offline
Old 12-15-2007, 02:34 PM
  #28
Sirsilent
Sirsilent's Avatar
Does anyone have picturesnow with wider tires on the stock 17" rims? I would like to see that
Sirsilent is offline
Old 12-15-2007, 04:12 PM
  #29
Viking
Viking's Avatar
255/50 17 Federal 595SS on the stock 17. Sorry for the dirtiness.
Viking is offline
Old 12-15-2007, 05:00 PM
  #30
ratnacage
ratnacage's Avatar
ORIGINAL: Drew47000000
Will I really loose a signifigant amount of handling going up to the 275's? Im not a autocross enthusiast, but like I said it is my D.D and I'd hate to do something id regret and have to deal with everyday... I just really like the look of a huge fat tire in the back and think it will be GREAT for the strip!![sm=helpout.gif]
It's not just racing handling - you have to consider everyday driving. Having tires too wide for the rim can lead to a very unstable car in turns or foraccident avoidance.
ratnacage is offline
Quick Reply: These tires will fit... RIGHT???
