Buying Mustang questions.
RE: Buying Mustang questions.
ORIGINAL: 28HopUp
All S197 GT's have a 8.8" rear-end, while the S197 V6's have the 7.5" rear.
To the OP: [ul][*]The IUP (Instrument Upgrade Package) is nice, and includes aluminum dash panels and the MyColor dash feature, but that shouldn't kill a deal for you (you can buy various dash panel kits).[*]I like having the side impact airbags on my S197's (they're located on the seats, and cannot be added later).[*]Check to make sure the car has (or doesn't have - your preference) ABS and TCS (traction control system), as those cannot be easily added to the car later.[*]The integrated/activated alarm system is nice. It keeps creeps from reaching in your open window to remove things.[/ul]
ORIGINAL: acascianelli
8.8" I think, I'm not sure on that one.
On the 8.8 rearend, does it hold up well? Any problems with broken axle shafts (obviously probably not in stock trim but once nitrous or a supercharger is added)? Is it common to upgrade to a 9inch? What rear axle does the Shelby run?
The 8.8 holds up pretty well. There are tons of FI people on this site with 500+ hp and still using the stock rearend and axle. The first to go would be the block, then the tranny and your rearend a little farther down the line. I think the most common switch for the ones that do, is to the Detroit Trutrac, but I believe thats an 8.8 as well. To my knowledge, all aftermarket companys (Saleen, Roush, Shelby, etc) run the stock rearend.
To answer your question about which gears people go to, it depends on the plans for the car. Most people who go FI switch to 3.73s and those who stay N/A switch to 4.10s or 4.30s.
The difference between the 500 and the 1000 is, the 1000 has 2, 10" subs in the trunk along with the 2, 8" in the doors. Theyre by no means top of the line... but at least theyre tuned for the box theyre in, so they sound decent and provide some extra bass. Its something you should get if you arent crazy about audio but still want something decent.
ORIGINAL: 28HopUp
To the OP:
[ul][*]The IUP (Instrument Upgrade Package) is nice, and includes aluminum dash panels and the MyColor dash feature, but that shouldn't kill a deal for you (you can buy various dash panel kits).[*]I like having the side impact airbags on my S197's (they're located on the seats, and cannot be added later).[*]Check to make sure the car has (or doesn't have - your preference) ABS and TCS (traction control system), as those cannot be easily added to the car later. [*]The integrated/activated alarm system is nice. It keeps creeps from reaching in your open window to remove things.[/ul]
To the OP:
alot of people slap 4.10 gears; but if you want a DD/gas car keep the 3.55's. I have the skr500; its been a pain in the *** but is great when it works (mps are the problem).
Yes; there 8.8
I would also recommend trying to look at a new GT, there always making deals on them. You know; you know your the only owner.
Yes; there 8.8
Cool! it just so happens that I am selling questions! What kind of question would you like to buy? Just Kidding, stick around awhile and read, read, read. Before you know it youll have all your questions answered.
If you plan on selling the car within 3 years you should get all the important options. Shaker 1000 won't add much, but things like IUP, 3.55 gears & leather will.
What's more important, if you are buying from dealer stock, is that you HAVE to test drive the car! Drive around the neighborhood around the dealership before you stop in looking for real rough roads, speed bumps or humps, or maybe uneven road. Then go on those roads on your test drive. Keep the windows up, to listen for any rattles inside, especially from the dash, then go back with the windows down to listen for any popping or rear axle noise. Let off the gas and hear if there's a difference in the whine from the gears. Do it at both slow and moderate speeds.
Also, be sure to check the engine! Check the brake reservoir- does it have fluid leaking around the top? Most used ones do because they are overfilled and leak.
Best bet is to keep searching for problems have been coming up with the S197 and make a list. The salesman won't know anything about these so have him introduce you to the service advisor who handles Mustangs, if there's such a thing.
Oh and GOOD LUCK!
Oh and GOOD LUCK!
