Hard to fill up
Hard to fill up
Don't know if anyone else has noticed but are you cars difficult to fill up. I have tried level, incline, different stations and all that and I can't seem to get my car to fill up very easy. My car can be empty and after only about 3 gallons the lever clicks off.
Any suggestions or thoughts or similar problems.
RE: Hard to fill up
I've found it's certain filling stations that have that issue with my car. I've only had it happen 3 times in a year and always at stations I'venever stopped at before. Ford has a TSB out and from what I've heard it works.
RE: Hard to fill up
I use to fill with the handle at the 2-3 o'clock position to get it to work. Tried something different the other day and it has worked the last two times.
Turn the handle to the 3 o'clock position, start to fill, then rotate it around to the normal 6 o'clock as you continue filling. This works for me.
RE: Hard to fill up
I've always had this problem, and was just about to post about it today.
There are gas stations that I just don't go to anymore due to the difficulty. It seems that if the fuel delivery is fast, we're out of luck.
Either way, it was a drag all winter...had to stand out there three times longer than normal, and locking the gun and getting back in the car is a thing of the past.
